Enhanced Camera Symbols
We could really use some enhanced camera symbols for plan and elevation views.
The circle ( which scales to the area covered by the camera) is not usable for large areas of coverage. It winds up looking like a giant circle on your plan view! Not professional or standard looking at all.
The rectangle shape is a little better but winds up cluttering the drawing when you have many sections to call out on a plan view or ga view.
The rectangle shape does not look like a "cad standard" ..... it' does not look professional. It also has a line going thru the center that adds to the clutter.
We need the ability to choose standard cad section symbols for the cameras that give you the option to attaché advance tokens to customize the information provided the same way the labels allow you to do this.
It seem like the basics ideas are there for the camera symbols but they need to be enhanced in a major way to bring Advance into the same league as Tekla  and SDS2.
Please code this in.
Regards
Craig
1 Kommentar
rinaldoPV7JY
Even a simple option to select the linetype.  The solid object line box or circle is terrible.  FIX THIS ASAP
Idee einsenden
