Edge processing - Bevel cut for Hollow Sections
For butt weld usage to tube sections, the edges of the tubes need bevel cuts on the entire contour. If I have lots of tubes with different sections, the bevel cuts cannot be multiplied from a tube to a another with different section.
e.g. From RHS120x4 - to RHS120x5 the bevel cuts cannot be copied.
This generates a lot of time consuming work for something minor such an edge processing.
Idee einsenden
