DRAWING STYLE DIMENSION DEFINITION
I would like to have the ability to ENABLE or DISABLE certain dimension definitions/chains within a drawing style. Sometimes, you may get unwanted dimenisons thant can/should be enabled or disabled instead of deleting or adding the defintions. Also, to make it easier to see which chain is which, should have the ability to turn the labels ON or OFF globally. Maybe even autogenerate an alphabetical ID label based on number. Line 1=A, 26=Z, 27=AA etc. These labels help identify the dimensions on the drawings, especially when there are in some cases over 50 lines of chains.
1 Comment
haedicu
Thank you for this idea.
We will take it in consideration for our future roadmap.
best regards
Udo
