Drawing Style - Base Plate Assembly with Landing Plate
Need assembly drawing styles to have the ability to include landing plates in the view along with base plates, anchors, and the column.
If I create a camera at node and run one of the 'Selected Camera' processes, the landing plate is included, and the view itself is good. However, the view title is looking at the camera properties instead of the assembly. (See image: Drawing Process Using Same Style.png.)
If I run the drawing style by itself (derived from assembly style '5 - Column'), the view title gives the desired result, but the view does not show the landing plate even though the anchors allow room for it, the upper end of the view is clipped and visible (not desired), and the view title had to be manually modified.  (See image: Same Drawing Style from Process.png.)
The third image is the closest to the goal, but still needs to show the landing plate. (See Image: Desired Result But Include Landing Plate.png.)
What I don't understand is that the drawing process (Selected Cameras...) is calling the same style, but when I run it both ways the views are different.
Zip file provided contains sample project, exported drawing process and style, and images mentioned above.
2 Kommentare
Flies-Eyes
Is this an Idea or a Question?  My first suggestion is that Camera can get the Drawing Style from 2 different locations.  The one included in the camera will over ride the drawing style in the drawing process.
What you need is a small change in your detail style for columns:
So you could easily select the additional landing
Idee einsenden
