Drawing style and drawing process managers - should be combine
The drawing style manager and drawing process manager, should be combined into one interface, or at least have the ability to both be open at same time.
when using this interface references are made to different parts of both interfaces, at present take screen shot, close one open other, then adjust, then return back to previous interface. Very time consuming operation.
also in the drawing style manger, there should be similar opitions to windows explorer, feature like open in new window , so you can see the source and then the extended interfaces.
the interfaces should flow easier, like windows has developed over the years to allow users to open in new window or tabs,  having to swap back and forth is time wasted in editing.
Idee einsenden
