Drawing Numbers Available In Lists On Drawings.
Give users the ability to put drawing references in lists on drawings. For example on a multi-part drawing, I use the "SP Quantity Per Assembly" list to indicate which assembly each part belongs to but I would also like to include a reference to the drawing that the assembly is on. This ability would allow for better traceability between parts and assemblies on large projects.
4 Kommentare
Bogdan.O
Status geändert in: Under Review
Matheus.costa
It will be important to reach out in which drawings the parts of an arrangement drawing are detailed. Autodesk give attention to this idea, it is very important resource!!
Nicht anwendbar
RyanS-SDDS
Since I posted the original suggestion, I've worked with several different fabricators in western Canada that have asked for the traceability for parts/pieces vs weldments. Most fabricators have requested drawings for each individual part/piece with reference to the weldments that they belong to. Its time consuming to customize the lists and software to do the referencing which in turn make us less competitive in the market. Adding the drawing number token to the Lists on Drawings would reduce the extra effort required to meet our clients requirements. I'm sure we aren't the only detailers that have run into this issue.
RS
Idee einsenden
