When the Double Purlin Splice Plate connection macro is used with overlapping purlins, the plate does not connect to both purlins as it should. Only two bolts are inserted in each purlin instead of all four (refer to attachments). It would be great if the connection was enhanced to take overlapping purlins into consideration.
