Per attached example, holes in elements that sit behind other elements shall be represented with system+hidden lines only, no hatch.
This is a rule that is not implemented anywhere in Advance.
Including beam and column drawings-holes in webs shall be hidden-system for top and bottom views.
In this example, shear plates are behind the moment plates, hatch is not supposed to be visible.
If the part is hidden ( and represented hidden), does not make sense hole to be represented as visible (with hatch).
I hope this will be fixed before AS2017 gets on the market.
Ilko Dimitrov
