This is the fourth time I am requesting the developers to look at this issue, because it is not done properly in Advance.
This was submitted through the idea station, also-tech. support last year, it was submitted through Ember version as well, it is still present.
Per attached 3 screen pics:
1. Holes in angle legs that are in far side leg are shown with hatch-this is wrong, such holes shall not have hatch, system line and hidden line only.
2. When holes are in beam's web, and looking from top, holes do not have to be hatched, system line and hidden lines only
3. Per the third file: holes in HSS that sits even behind a plate is shown with a hatch. This is the worst so far I have seen. This does brake all known rules for preparing construction documents.
I will submit this 'idea' each and every year until someone sits down, thinks about it and fix it in the default database.
Ilko Dimitrov
