Display zero inches in BOM Lists
Display zero inches in BOM Lists. Currently saw lists, etc, display for example: 3'-0 1/4" as 3' 1/4".  This leads to shop errors with beams cut at 3 inches instead of 36".
Zero inch display is needed in BOM's for clarity.
I know this function can be turned on and off in detail drawings, but there is no way to accomplish it currently in Lists.
4 Kommentare
there's a default in structured BOM/NC-Generel: "suppress the last zeros (used for BOM)...this should be the one you're looking for or not?
ajonesgml
It does not affect BOM
this was only an idea, I don't use it because the we need the  metric system :grinsendes_Gesicht_mit_großen_Augen:
acbsdesign
This used to be ok in the past, they have changed it.
Some companies are very sensitive about ABOM.
Currently external lists do not follow AISC requirements for dimensions.
Idee einsenden
