Dimension Tolerance in Details Drawings
Please add the feature in Advance Steel to set tolerances on dimensions, as AutoCAD.
On AutoCAD the properties panel of the dimension allow to add Tolerances. Picture: 6_AutoCAD_Tolerances.png
But the Advance Steel Parametric Dimensions are unable to have tolerances. Not possible in Properties panel or Advance steel Dimensions panel. Picture: 6_AdvanceSteel_Param_Dimension.png
Idee einsenden
