Dimension hole pattern in beam flanges to first hole only
Currently Beam Dwg style places ordinate dimensions for holes in flanges to all holes, this creates unnecessary overcrowding of drawings.
Drawings would be much cleaner if ordinate dimension is placed to the first hole only, and the rest of the holes having relative dimensions only.
Dimension hole pattern in flanges to first hole only 1.jpgDimension hole pattern in flanges to first hole only 2.jpgDimension hole pattern in flanges to first hole only 3.jpg
1 Kommentar
acbsdesign
This one was coordinated with @gabriel.costin , it can be done by modifying the dimension chain, this is the link to Gabriel's info:
https://forums.autodesk.com/t5/advance-steel-ideas/add-extreme-left-or-extreme-right-hole-point-defi...
Thank you very much, Gabriel.
Ilko Dimitrov
ACBS
Idee einsenden
