Different dimension styles for Drawings
It would be very helpful if we could set a drawing style to use different dimension styles in a same drawing. For example, I could set it to use one dimension style for dimensioning some object with Model Role "X" and a different dim style (without extension lines, for instance) to objects with Model Role "Y".
2 Kommentare
haedicu
Status geändert in: Future Consideration
Thank you for this idea, We will keep it for the moment as a tracked item for future improvements on Advance Steel drawing creation.
best regards
Udo
Austruct
It would be good to have different dimension styles for running dimensions and string dimensions.
Example: running dimensions to have 2mm text and 3mm text for string dimensions.
Idee einsenden
