Detailing special parts using a Drawing Process
Hi again: Frau (zwinkernd)
The issue is I cannot detail the special part on any drawing.  If the special part is welded / bolted to a native model part, then yes it shows up on an assembly drawing.  However,
I still cannot select it.
It would be great if I could use the Drawing Process to detail the special part and have it detailed on a part drawing, so someone can fabricate the item. I can use cameras and use the drawing process to create a drawing of the special part, however it would be just peachy if I create a “Solid” detail style for both MP assembly and SP drawings so in the future I do not need to do hacks to get something on a drawing?
Juss sayin:Frau (überglücklich)
Best regards,
Janet
Graitec CANADA
2 Kommentare
I do it like this, for customers which really need it:
  • create a beam, plate or whatever you want with a specific role like "specialspecialpart" :grinsendes_Gesicht_mit_großen_Augen:
  • create a mp detailstyle and a modelrole for this specialspecialpart and set this modelrole to "not shown"
  • so the special part is an "attached part" and could be shown, could be cutted and so on.
  • but in the model this "specialspecialpart" had to be defined as mainpart
janet_black
Thanks Sebastian:lächelndes_Gesicht_mit_lächelnden_Augen:
Idee einsenden
