By changing the dialog in AS2017.1, some user have the problem not have the opportunity to made detail cuts by using a command with a special key (from the database).
Until now we could define commands, so we could made detail cuts with our own detail style without click on the button "Detail cut", found the correct detail style and then made the detail cut. Now with the change of the dialog, the command for detail cuts is changed and the old command could not used anymore.
So here's an idea, to make the detail cuts on drawing faster:
We need an extra category in the detail palette "Detailcut on drawing", and according to the connection vault palette, it would be nice to define "favorites" which could be add to this category (or by using the detail style manager this is not relevant)
Picture 1:
So if we could handle it like this (or second palette only for drawings) the cuts on drawing are very fast, and we we could decide to make our own categories. For example: category for overview cuts, special cuts for stairs and so on.
greetings Sebastian
