Detach Multiple Connections with one click
When using "Remove Joint from a Joint Group"... Please allow multiple connections to be removed in one selection set.
From the command line:
Command: _AstorDetachSlaveJointFromMaster
3 found
More than one connection found in selection set. Please select only one!
1 Kommentar
DumitruBerteanu
Status geändert in: Under Review
Idee einsenden
