Default for"Weld type" or add "Weld type" as parameter in common connections
For most of the joints, the welds are created with "a" weld type, depending on each joint.
Some are creating "Double fillet weld", some "Fillet weld" only for Main weld, others "Fillet weld" for both sides. And some joints have the weld type as parameter.
It is not easy to set the desired weld type for the entire project.
The feature request would be to have a consistent way to control the weld type for a project, by:
- either a default "Weld type" that would be taken into account by all (common) joints;
- either to include the "Weld type" as parameter for all (common) joints, so it can be saved in the joint Library.
Thank you very much
Emy
1 Kommentar
Nicht anwendbar
Hai Emy i agree, it will reduce the  time very very much  in making workshopdrawings. In holland there is a big demand for this.
Idee einsenden
