Decouple coatings from joint boxes (macro connections)
Please decouple coatings from joint connection macros.
This would allow us to utilise a common connection across an entire project, rather than needing to separate the joint boxes per coating type. Coatings are sometimes altered retrospectively, which requires us to either remove joints from joint groups or removed joint boxes entirely.
We have a lot of duplicate connections due to coatings, which requires additional micro management of these joints.
2 Kommentare
Also do this for phase,
i did buy "ASbooster" to solve this problem
Austruct
We have also created a case with Autodesk for Decouple numbering from joint boxes (macro connections).
We have found on numerous occasions were the system overwrites the numbering with the master joint part numbers, causing a huge number or errors and duplicate numbers.
Very disappointed with Autodesk's response:
  "I received an update from my development team that it is indeed the current implemented behaviour for attributes of grouped connections to propagate to all when joints are modified, including the numbering. I understand that this behaviour is not desired"
Idee einsenden
