Creating spiral staircase like Revit
It would be nice to be able to create straight and spiral stairs as you do in Autodesk Revit. Advance Steel ladder creation does not allow you to create a landing along with the ladder. It would also be nice to be able to eliminate just a few elements without eliminating the entire ladder. Example, if I want to delete one of the stringers only, there is no way.
Idee einsenden
