In AS2022 we have now the possibility to select objects you want to see in 2d drawings. However, this ensures that revision will not work properly. If you select beams in a camera and create a workshopdrawing, there will be only beams in it, that are selected in the camera. But if you model a new beam in your modeldrawing and in the reach off the camera , you have to manualy add this again to the camera, to insure the revision will work properly.
This is making Advance Steel week. The revision of AS is one of the best of all steelconstruction programms.
I do not understand why the development did not choose for adding the filters, created in the project explorer, to the camera or export them into the workshopdrawing. Because then , when you change a filter in the camera or add a beam into the model , the document manager will recognize a change in the model/drawing and the revision will work as it should be. Because there will be no selection involved.
I hope i described it well, as not i will see it in the comments
Again for the develepmont, please look into it.
Regards Carlo Heisterkamp
