create cut view with same scale
In as2016 when you create a cut view in a workshopdrawing you had the possebility to set the scale the same as the view you took it in.
Now tou have to enter a "s" from settings change the scale from default to the scale you want and then click op ok. (the default takes the scale of the drawingstyle )
A LOT OFF CLICKING. Why not have the possebility to set the scale the same as the view.
Maybe in MT or inthe command itself as it was in 2016
regards
carlo heisterkamp
2 Kommentare
AntDrt
THANKS !!!!!!!
the new workflow of cut and detail creating is like HELL, user doesn't have access to options that were available before 2017.1
(Title management, set part of center of the cut view...)
Back in 2017 method ! it was very simple...
corentin_prigent
Hello
Create the cut view at the same scale was much better than wasting time and clicking with settings
to redevelop in future version
Thank you for this request
Idee einsenden
