crashing programs are not ok
closing a 3D drawing results in a crash in 75% of cases.
I use AS from 2016 and each version can not properly close a drawing.
I think the problems start when you start using the document manager in your 3D model.
if you are not active for a while in the drawing and you want to close it afterwards you get a crash.
This problem is known to our distributor and autodesk.
After every crash I have forwarded reports to autodesk and a response has already been made.
But what I do not understand is that a company with 9000 employees can not even adjust in 3-4 years a program that can close in a normal way. I do not want any extra functions, I want to see the functions that are already there working in a normal way.
How the hell do you explain to newcomers that it is normal when you close a file that you have to make sure everything is saved.
Giving people a "drawing recover manager" is not fixing things!!!!
its giving a bucket when the boat is leaking.
1 Kommentar
filip_denolf
I will put up a log with all the crashes i get.
i also will start with a blanck template drawing.
And see if it gets better.
Idee einsenden
