Correct Names for Beveled Washers
Having the units set to imperial in MT, some beveled washers have names entered incorrect-it shows metric value Mxx.
Below is an example:
Ilko Dimitrov
2 Kommentare
haedicu
Status geändert in: Future Consideration
No sure if i get this correct, Ilko: Your request is to get a British Standard metric washer to be called in imperial units?
Can you order such a metric washer in U.S. using imperial units?
The washer name here is just a text, entered to match the standard.
acbsdesign
The names are entered incorrect in the database.
In this case-an imperial size washer 3/8" is entered as M10 (Metric)
This is a default in the installation.
Idee einsenden
