Correct Alphabet in Grids
Please teach the Grids command the alphabet in English. The letter 'I' does not exist and it has been an issue for at least 2 versions.
2 Kommentare
Drawtech
Sometimes grid letters that can be mistaken for numbers I/1, O/0  etc are omitted.
The database table AstorBase : GridMultiLang has a column CharsToBeExcluded that you can edit as you wish.
Easiest via MT table editor, but could use SQL queries. E.g. “i,o” or “I,O”
If blank, then no letters will be omitted.
ashleyhamilton18
@Drawtech Thanks! That worked to get them to show correctly!
Idee einsenden
