copying dimensions from one detail to another
I would like to be able to take dimensions that i have added to one section cut to a similar section cut. For example, the two side views of a stair frame.
3 Kommentare
iwafb
ETheuring
I find your idea not bad and I know this possibility still from very old Advance Steel or Hypersteel versions.
At that time, however, these dimensions were still a right AutoCAD dimensions.
However, with the right AutoCAD dimensions there were many other problems which there are not today any more.
I think, the better idea is another:
A possibility to select all detailed properties incl. manual dimensions and annotations to transmit on other details.
Moreover, it should be possible to save the selected detailed properties as a drawing style.
pinnacledrafting
Copying AS dims from drawing to drawing would be helpful. Right now I as dimensioning my stairs with Autocad dimensions and copying those.
Idee einsenden
