Copying assemblies with pre assigned master joints.
When coping a complete assembly in the model via the Advance copy dialog box, the joints break their link to the master. Then we have to be relinked the joints to the master connection. The relinking process is painful as only one joint can be added at a time to the master. Which leads me to my next idea, Multiple add joints to Joint group (master joint)
3 Kommentare
if I had more then one Kudo, I would give it to you
mcwallautocad
The simple solution here is to maintain the link between the Master joint and all it's copies.
Autodesk should update the software accordingly
We are always trying to save as much time and re-work as possible.
Autodesk should always do the simple things that make big productivity differences first, before adding fancy bells & whistles.
ppl
This idea is from 2017 and still not possible. Please add this into Advance Steel, much needed and would speed things up a lot! Also a browser for joints (with their naming, selectable) like the model browser would be much appreciated!
Idee einsenden
