When using copy clip in Advance Steel, Autocad objects are copied from the current UCS whilst Advance Steel objects are copied from world UCS without considering the current UCS orientation.
This fault makes it very difficult to copy objects to be pasted into another drawing or within the same drawing where rotation is required. For example Perth stadium where a lot of repeated steelwork is rotated slightly around the football oval, or a chute where liners need to be copied and rotated to all sorts of angles. Advance copy and rotate cannot be used for these scenarios where rotation is not a simple angle.
I know there is a workaround where you have to create a block of the object to trick advance steel into thinking it is not an advance steel object but this can be time consuming and difficult to track what blocks you have exploded and purged.
Please can the developers fix this fault in Advance Steel so that copy clip can copy Advance Steel objects relevant to the current UCS?
