Coordinate dimensions in callout views
HI All,
There should be an option to control the origin of coordinate (running) dimensions in the callout views. The options should include:
  1. Ability to select 0 point reference in main (overall) assembly
  2. Ability to relate "continue" coordinate dimensions from selected dimension value
  3. At least, the ability to manually adjust the starting value of the coordinate dimensions (force 0 to be 7320). Although this is least preferred.
As far as I can see, this is the best way of splitting large assemblies. Much better than cameras because:
  1. Cameras take extra time to insert in model.
  2. Camera views take extra time to generate.
  3. Cameras cannot isolate an assembly, you get all adjacent assemblies/parts which you then need to delete. Not great as you can delete or leave the wrong parts.
Dart
Idee einsenden
