Since Advance Steel 2014 it is possible to generate corner cuts also in beams.
Unfortunately, these corner cuts are not recognised with the control of the necessary views.
This leads to the fact that with a beam no additional view generates if the beam has such a corner cuts. Then one must generate either these corner paragraphs, like in the versions before it, as a contouring, or one must switch on the view by hand.
The control of the necessary views must be reworked by the development.
