Construction Lines
Construction Lines
1-Construction Lines
These must be invisible to the structure itself, they should not be shown on the fabrication drawings, although they might be visible. By default these should not be indicated in the drawings.
1 Kommentar
there're construction lines in AutoCAD. These are not visible in fabrication drawings. if you don't select them, they are not recognize in the Overview drawings by using the detail styles palette. if you use the camera they will be  shown, if you activate the "show AutoCAD objects" in the defaults in the Management Tools.
But maybe I don't understand this idea correct.
Idee einsenden
