Concrete Slabs
Concrete Slabs
It would be great if the Polygonal Slab tool actually worked using a closed polyline, like the plate tool instead of selecting points which then means you cannot get a curve.
Many times I have had to try and model curved concrete slabs and found it difficult to do. The only way I was able to do this was as a polyplate with material set to concrete, which is not the best option.
1 Kommentar
haedicu
Status geändert in: Accepted
Idee einsenden
