Can we have a command for a circular end plate within the connection vault.
It's quite a chore having to add 4 fillets to a square plate each time to achieve this. Also if you then change the CHS diameter afterwards you've then got to change the 4x fillet radiuses again. Whereas the square plate on square section updates automatically if you change the section size afterwards.
