One last one for the day
when you dimension using the advance steel labels and dimensions
it would be nice to be able to change the odd extension line to a different line type like centreline? Even ga drawings is strange
In regular AutoCAD you can simply hit the dimension right click properties and then have the option to change the continuous line to any other line type
It does look strange when we dimension to the centre of an object with a solid line.
i know you can set the dim style to show all ctr lines but that is not ideal as fellow detainers would probably agree
thanks
