Change the original drawing style of detail to one with different no of views
If you try to change the drawing style (DS) of an existing detail by applying a DS with a different number of views, you get an error message:
  • The drawing styles are not compatible. The numbers of views don't match.
and you cannot continue.
The feature request would be like that:
As long as I am trying to apply a different DS from the same category as the original DS (SP with SP, MP with MP, Overview with Overview), I should be able to do it.
The DSs should be compatible when they have the same "Model object selection" option, regardless the number of views.
The new DS will take all the info about the "Model object selection" from the original detail and will apply the new DS accordingly.
Thank you very much
Emy
12 Kommentare
Nicht anwendbar
Hello Emy,
your istructions are corrects, infact I can change from "Column" drawing style to "Beam" drawings style, these have the same Assembly category.
The issue appears when I try to change from the "Beam" drawings style (Assembly category and MainPart object selection)
to a "Stair" drawing style (Stairs & Railings category and MainPart object selection).
In this case we have:
- Same object selection
- Different categories
- Different number of views
With your succestions, I should to do, but it doesn't work.
Could you check it, please? Many thanks.
Emanuel.Nestor
Autodesk Support
Hello Gabriele,
Indeed, it is not working when there is a different number of views.
This is the Idea / Request from this post: to be able to change the DS when the number of views is different.
If you agree with the request, you could vote for it.
Best regards,
Emy
Nicht anwendbar
Perfect, thanks a lot.
Nicht anwendbar
we also want this feature again as in AS2016
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
Nicht anwendbar
This is extremely frustrating. I have this same problem now, 2 years after it was brought up. You guys need to do better, there is no excuse for this lack of development.
95r380disco1
I am currently having the same issue now. It looks like this was never fixed 3 1/2 years later
Nicht anwendbar
They (advance steel management) have a list of known bugs in the program, but if there's no monetary value in correcting them, they get forgotten. They only arrange the bugs that they know will cause people to change programs. Just lower your expectation from them and you will be much happier with the product! The project manager for AS has a very easy job.
Nicht anwendbar
2021, this issue is not yet fixed.. amazing
j.hamelin
2023, 6 1/2 years later... still not fixed................................................................................
SWS77
Seems really silly this isn't fixed yet.  Why can't I create drawings, look at them, and decide I want a side view added to the style, and just change the style?  This should be an easy fix.  Please work on it for the next update!
bigcarl5000kg
Dear @Emanuel.Nestor,
after 6 years and almost 6 months, no change for the better... what feedback does the developer have for the paying users?
Idee einsenden
