Centre of Gravity for assembly to be shown in assembly drawings
Hi All,
Currently, the workaround to display the COG for an assembly is extremely cumbersome. Not to mention nearly impossible when the assembly is clipped in the detail. To that end, we need to be able to turn the COG on and off within the assembly detail. Ideally, this should be set in the drawing/assembly properties, not the drawing styles. This way, it can be turned on/off on demand.
Thanks for considering.
2 Kommentare
95r380disco1
It would be nice to add scribing of a cg line in the top flange of beams also in the NC files.
bigcarl5000kg
A primitive function that every 3D CAD has - does it need AI to implement it? :strahlendes_Gesicht_mit_lächelnden_Augen::daumen_hoch:
Idee einsenden
