Within the camera, there is currently no object selection method.
But within the system there are several ways to create selection sets, by search/query method , also groups can be used to select objects.
Also the model browser can be set to only show elements from a model view, when active.
Can this ability be linked to the cameras, so that objects from these selections methods could be linked to the camera , thus giving a dynamic input to the camera rather than a fixed selection set.
So for example to activate a floor plan model view, we see the beams and the columns, but trying to do as isometric view the beam elements above and below show in the view generated, rather than just the required floor level.
If there was option to say based upon model view then this would only show the elements from the model view enabled. Also if elements are added within the model view then those would then show in an updated drawing, thus removing the issue of selected parts and not be able to update the initial selection set.
Same if there was option to link with a query or a group, these searches and groups can be run and updated also, as the model progresses.
This would then link in with the other uses of searches for status of objects for approval, lot and phase reference, fabrication data.
