Camber token for external lists
One of my our customers requested and camber column in the external material list back in 2019. At the time the token for "radius" (|radius) in the field content listed the camber every time (see "Camber Issue on BOM" attached). Sometime between then and now something changed so that the camber stopped being listed (see "Camber Issue on BOM-2" attached). Per tech support (Sophia Li and Emy Nestor - thanks for you help:lächelndes_Gesicht_mit_lächelnden_Augen:) it was suggested to use a user attribute and to post the idea here.
I would like to see more tokens (especially one for beam camber) in the field content token list for external lists.
Bill
Idee einsenden
