Calculate the cut number
There are two systems of cut numbers in central Europe. One from Salzgitter, one from Klöckner. All the other steel trader use one of this systems. It will be a good Idea to calculate the Number of de cut an then put the result into a attribute, which can be used for reports. This calculation of the cut number can be done when the numbering process is working.
Example for a Klöckner code:
HEB200 - 500 / FIG: 21/45°
or
HEB200 - 500 / FIG: 23/45°/45°
or same example in Salzgitter code:
HEB200 - 500 / FIG: B/45°/45°
What the user need is the number or letter of the figure in one variable.
exemple:
FIG: 23/45°/45°
This figure wil be written on the list to ask a offer for steel or to order steel. Steel trader use the nuber internal to cut the beam an bring it on the right length. They don't use  DSTV files.
The system today, with the cutlist with symbols, is not enogh to order beams or ask for a offer.
2 Kommentare
haedicu
Status geändert in: Under Review
haedicu
Status geändert in: Archived
Unfortunately this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it. Please feel free to rework and resubmit this one down the road.
Idee einsenden
