Cage Ladder With Side Opening: Put Checkboxes On Same Tab With The Actual Settings
When setting up a cage ladder with a side opening at the top, you have to go to the Cage > General tab to check the box, Finish Cage At Exit Level, then go to another tab to configure it, Exit > Top Cage.  There is no reference explaining that in order to access the actual settings you have to go to a different tab to activate them.  Requesting that if a check box is needed to activate other settings, that check box be placed directly above those settings on the same tab in Advance Properties, or at least a copy of that check box in both places.  See the attached file for more info.
Idee einsenden
