Bubble labeling
Bubble labeling
we could create labels with round frames (bubbles). But by using it, there's no option for set the text to Alignment Center
The result is looks very bad and if you activate leader line, the result is definitiv not usable.  If you use a second line, maybe in the first line the  MP number and in the second line the profilename or SP number, the result could not be publish to customers.
So we need more options to customize the labels:
  • text alignment
  • leader line should be connect to the bubble not to text
Idee einsenden
