bracingconnection also work if bracing is not alligned with xy plane of mainbeam
If i connect a bracing to a beam , but my bracing has an other direction then the XY plane of the mainbeam, the connection will not work.
In construction work this situation is common.
So my wish is to change the bracing connections "Gussetplate to column and baseplate"or "Gussetplate at one , tow or three diagonals". So i can use this connection also if the bracing is not alligned to the mainbeam.
Regards
Matrix-Software
Idee einsenden
