Hello ,
If the bracing has a little bit angle difference on the UCS of the connected beams, the bracing connection are not working and do i have to model it manualy. Is it possible that there is some kind of tollerance so if the bracing has a angle diffrents of 1 a 2 degrees with the connect beam, the connections for instance ( “Gusset plate to column and base plate”) is working.
