bracing and the direction of the outstanding leg
Can you please add a switch in the bracing macro to mirror single angle bracing so I don't have to mirror the angle that is toed the wrong way. The mirror command in the macro only does one plane of mirroring, it needs two!
I often am using this macro to do single angle knee braces, and I want the outstanding leg facing me. Same issue with horizontal bracing.
This mirroring I find always reverts to the original alignment when adjusting connection macros and quite frankly is annoying and time wasting. I have tried manipulating the UCS to achieve opposite (desired) results and have not had success.
1 Kommentar
mick-CNF
Idee einsenden
