BOM editor - disable closing the window via ESC / add warning message for saving the data
If ESC is pressed after setting the parameters for the user BOM, the window closes without a warning message and nothing is saved. It can be very painful - please correct this illogical behavior.
2 Kommentare
bigcarl5000kg
An example: this behavior also applies to other editors / managers in Advance Steel - here is always the important definition possible and the "Apply" button appears:
Julio_Soto
Ahaha I feel your pain!
Idee einsenden
