BOM Column widths you can *ADJUST*
This is Advance Steel 2022 and the default template/drawing styles for stairs won't fit a default grating stair tread without the text running over into the next column.
I have to go and customize my BOM templates to suit?!?!?
Do better AutoDesk this is unacceptable.
2 Kommentare
Julio_Soto
Just be happy it doesn't get truncated as it will in the External BoM editor.
I agree with you though, the auto cell formatting in AS leaves much to be desired.
Garret_H
Oh look Advance Steel can't even fit a simple cut beam in its default BOM tables. This is such unacceptable garbage.
Idee einsenden
