Bolts-(N) or (X) to be taken automatically when performing connections design
Currently when performing design check for connections the N or X values have to be calculated and entered manually.
It would be a great if software is using N or X automatically based on bolt orientation and thickness of connected members.
Ilko Dimitrov
2 Kommentare
michaelaC4UXJ
Please vote for my suggestion if you agree with this posting as well :leicht_lächelndes_Gesicht: We want to see this implemented!
https://forums.autodesk.com/t5/advance-steel-ideas/bolts-bolted-connection-amp-designing-to-the-x-co...
acbsdesign
michaelaC4UX,
If I can vote another 100 times I will.
Thank you for the support.
Ilko Dimitrov
Idee einsenden
