BOLT CREATION- DOUBLE VALUES- easier way to differentiate Metric and imperial.
Hi again,Smiley (zwinkernd)
Most fasteners either come in both imperial and metric sizes or only metric and only imperial. When you list both and do the conversion you end up with a double listing in imperial or confusing results if you're using metric.
In the screen shot.....Please see attachment,  you can see it is a bit challenging to tell the difference between 12mm and 1/2".
I had to change the Unit Selection to:
Scale unit=Inch
Format= Fractional (inch)
Precision= 0 1/256
If the list had both a 12mm and a 1/2" option it would be much easier for the user.
Another way of doing this would be to not display metric sizes when the units are set to imperial and vice versa for metric.
The user could set the units according to the fastener to be created.
This might be better since the dimensions for the fastener need to be in the specified unit.
Please see attachment.
Best regards,
Janet
Graitec Canada
Idee einsenden
