To use BIM 360 glue interface, the advance steel model , needs to be converted into a 3ddwf file format , this can then be seen in the glue platform. This in turn can then go into the BIM 360 field interface, creating equipment sets to track installation process.
The issue is this is not a live dwg file , if the model changes then you have to repeat the 3ddwf creation and upload again a new model.
So need to make glue able to see the native dwg advance steel elements, like in BIM 360 team a AS model can be seen in that interface and the metadata can be viewed via properties.
This change would help with the merge model opitions in glue to link various different project elements, like in navis you can merge models for collision checking.
Also going forward into field this would allow better control of the AS model in that interface.
For BIM 360 team this seemed to make use of the object enabler to see the model file and the drawings in native format, also with need attached model data in 2018, there must be a way to extend this to glue and then back down into navis.
