Beams stretching along system lines (Lengthen), option within MT
It would be advantageous to have the Beams stretching along system lines (Lengthen), option within Management Tools. It is extremely inefficient/time consuming to have to right click every time.
Not having this as a fix variable is also subject to error. There should only be a right click option to Stretch.
2 Kommentare
bigcarl5000kg
Hi @Austruct ,
why in Management Tools? What do you want to store there?
Click on the beam, approach the end of the system and select S (as Stretch). This avoids a very tedious selection from the menu :strahlendes_Gesicht_mit_lächelnden_Augen: and have the same function
markhubrich
I think it would be useful for example if I could hold the shift key when selecting a grip to lengthen. No shift acts as stretch.
Idee einsenden
