Beam Drawing Style Improvement
Hi Udo,
Attached please find a screen shot of the most used drawings style by a structural detailer-Beam. Default AS dwg style is used.
Noted as 1: There is an unnecessary repetitive dimension (21'-11) - Shop does not need same dimension to be shown twice, even 3 times if we count the third dimension chain above. Please remove the repetitive dimension.
Noted as 2: Ordinate dimensions jump too far from the beam contour line, taking too much of a space, and also not being aesthetically aligned and closer to the beam. Please allow the ordinate dimensions from different dim. chains to be aligned by default, we will move them if necessary.
Noted as 3: This is very typical in Advance, and it is not per common sense rules: These two dimensions instead of being aligned, they are always offset one from another. Please allow these two independent dimensions to be aligned. As you can see, the ordinate dimensions for the holes in bottom flange are too far from the beam too.
Thank you and have a great day.
Ilko Dimitrov
3 Kommentare
acbsdesign
Same dwg style, cope depth dimension has to be the first next to the beam's end, holes dimension chain has to be on the outer side.
The rule is smaller values are closer to the contour lines.
First screen shot is the default in Advance, second screen shot is the two dimensions adjusted.
This is very repetitive and needs hours of work on a larger size projects.
Ilko Dimitrov
acbsdesign
Same dwgs style, sometimes dimensions appear at segments of a cope radius-I personally do not know what the reason can be; copes are made by a shear plate macro.
Below is a screen shot of them, this may be a bug. Please try to clean this, I will provide model and Assembly dwg upon request.
Also-RD symbol and dimensions overlap-please advise if this may be fixed from MT. If it is a bug-please fix it.
Ilko Dimitrov
Bogdan.O
Status geändert in: Under Review
Idee einsenden
